need some parts... BAD!!!
Old 06-30-2007, 05:35 PM
dracoran's Avatar
need some RB20 parts... BAD!!!
hello, I am a noob, so if I have missed the realevant thread, I am sorry. I am in desperate need of stock RB20 parts. I need a coolant temp sensor (which I have tried to match up to no avail), and a MAF. Any help being pointed in the right direction would be greatly apreciated. Thank you, Adam
dracoran is offline
Old 06-30-2007, 09:17 PM
just check out the classified section here and across other 240 sites you will find things also ebay bro.. lots of loose ends fly around there. im pretty sure there is an interchangeable parts list floating around. ill see what i can pull up for you bro
edit
lil list i compiled from other sites
PART JDM / RB20DET # USDM / KA24DE / VG30xxxx #
N1 Oil pump 15010-24U01
Oil filter 15208-00003 (KA24DE)
Genuine Nissan 15208-H8911 (AUS)
Genuine Nissan 15208-H8904
Ryco Z145A
Valvoline R9
Fuel filter 16400-53J10 16400-00002 (VG30DE, VG30DETT)
***Subaru Forester filter works
Fuel pump 17042-00003 (VG30DETT)
Fuel injectors
Denso 440cc 195500-2010
non-turbo, 1989-1991 Mazda RX7
Denso 550cc 195500-2020
Thermostat 21200-42L00 21200-00001 (VG30DE, VG30DETT)
Nismo Thermostat 21200-42L05
Clutch
***1990-1996 VG30DE shares same clutch assembly
Spark plugs 22401-000036 (VG30DE, VG30DETT???)
NGK standard 1.1mm PFR5A-11
NGK Iridium 0.8mm T7341T-8
Trust-Greddy Iridium 0.8mm IT08
Water pump 21010-21T25
N1 21010-24U27
Coil packs 22433-60U02
***RB20DE, RB20DET, VG30DE, VG30DETT, RB25DE share same coil packs ???
Rod bolts
ARP 202-6005 ???
O2 sensor (which one?) 22690-73L11
Alternator belt 11720-24U00
Timing belt 13028-20P10
13028-20P25 (boxed)
Power steering belt 11950-04U00
AC belt 11920-42L01
Fan belt ??? 11720-42L02
Sump washer 11026-01M02
Air flow meter 22680-02U00
Speedo drive gearbox end 32702-58S21
Biggamehit is offline
Old 06-30-2007, 09:27 PM
dracoran's Avatar
thank you for your reply. Honestly, I have been looking for this sensor for about 3 months. I have looked on several sites, as well as ebay and craig's list. It may be that I have not found the correct thread or post in other sites. The Nissan dealer will not put me in touch with the Japan counter part either. I have taken the broken sensor with me to numerous places, and none have been able to match it, including the dealer. It is the 2 wire, yellow sensor in case anyone reading this has an extra . I have found replacement parts for the 25 and 26, but not the rb20. Thank you again, any assistance would be greatly apreciated.
dracoran is offline
Old 06-30-2007, 10:19 PM
sure thing man ill keep looking for what i think is good info.. there is alot out there but most of it is inaccurate and or duplicates
Old 06-30-2007, 10:29 PM
dracoran's Avatar
thanx for the list!! It will come in handy in the future I think. I am in agreeance with you on the inaccurate description of part numbers. I usually double check them before purchasing anything. I am still looking for the coolant temp sensor however... I can not do a test start of the car with out it...
dracoran is offline
Old 06-30-2007, 10:30 PM
wellll from working with Rb20s the temp sensor looks just like the KA's ill check it out
if it comes down to it you will have to gather a list of parts numbers for temp sensors which you can get from many online sites that sell them such as autozone etc....
take them to nissan and ASK for the part and information, dont tell them that you are trying to match parts numbers... have them write it down for you... if you decide to buy the sensor from them, you will pay 1million dollars for it.
Old 06-30-2007, 10:48 PM
dracoran's Avatar
the one from my KA does not fit, and has a different size cylinder internally. It also (I was told) has a different resistance level, however, i am not adept enough to actually test that for myself. The Nissan dealership was not even able to look up part numbers for a Skyline at all. I asked them to get me in touch with their Japan counter-part, but they said that was against company policy. None of the parts store web sites that I have looked at are able to locate parts for a Skyline either. Going into the stores.... ya, most of them don't even know what a Skyline is... LOL Does anyone know of a Japan based auto parts store? I am sure that they would have them, but I can not seem to find any.
dracoran is offline
Old 06-30-2007, 11:00 PM
try jspec.com dude
Ezra
For Sale - Part Outs
11-18-2007 10:11 AM
slcmuffinboi
12-04-2005 09:24 AM
orlando05
11-14-2005 04:12 PM
quick240sx
07-24-2005 12:45 PM
Nismo241
01-08-2004 11:05 PM
Quick Reply: need some parts... BAD!!!
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
