91-94 front bumper fit 89-90?
the bumpers for the 89-90 are different from the 91-94 bumpers right? can i just change my 90 bumper/lights to a 91 bumper/lights?
pics would help also
I'm currently having my 1990 painted, I liked the front end better on the 91-94 for I order one and everything bolted and fitted nicely. Only ran into one little problem, a small section at the bottom where the bumper meets the fender doesn't line up exactly, sticks out a bit. Gonna have it molded in but other than that should work fine.
Originally posted by ANVIL
so if i wanted to switch the bumpers out, id have to get new signals too? can anybody post some pictures?
ive swapped a 92 bumper and it bolted right on with exception with 1 stud from each side on the brackets that connect to fender..in which i had to drill a hole. the 89 fender is different from the 92 as part of the bumper sits lower than the fender..ill try and post the pics by tonight
Djrockz415 :
"ive swapped a 92 bumper and it bolted right on with exception with 1 stud from each side on the brackets that connect to fender..in which i had to drill a hole. the 89 fender is different from the 92 as part of the bumper sits lower than the fender..ill try and post the pics by tonight "
Do all the bumpers looks that mis-aligned when you convert them from 89 to 91 +? If they do I don't see the point in getting a upgrade cause it will not fit right which will make it look out of place .
I think they look puuuurdy. No but seriously they do look sweet. I dream of the day when I can afford one so I can have both and switch them up every now and then for the heck of it. What I really like about the 91+ bumpers is how there are two lights right above each other and how they are a sleek, oval-rectangle, shape and not just plain rectangle.
MAD240SX
Jul 20, 2018 10:38 PM
NismoHead90
Feb 19, 2010 02:43 PM
ToyoSupraR
Jun 3, 2006 01:39 AM
