92 coupe interior
I recently installed new carpet for the 92 coupe. I was going to try some refitting of a newer model year carpet, by softening with a heat gun, but attempts on my old carpet didn't do much good... the carpet takes a pretty stiff set.
So, I ordered a new carpet on the web, that was made by ACC. I emailed them and they told me the Hicas 4 wheel steer for 92 was only one available... no other molds.... and that it didn't fit a non Hicas car! So, I ordered it anyway... how different could it be.. Well, it fits perfectly..I can't tell from photos where it might be different from non hicas but it fits well... it is allready trimmed and installed..one note you do need to save the plastic edge trim strips from the original old carpet. After you fit and trim for new carpet, you staple these to the edge at the door sill and it will slip over the flange at the sill. These keep the carpet from creeping away from the sill and exposing the raw edge. Also since I am going to get rid of the automatic seatbelts I fabricated a small sheet metal cover to go over the old seatbelt bumps in the rear seat area. I padded these with carpet pad and the new carpet fits perfect. The new carpet didn't have any holes cut in it so the bump out areas are completely covered. |
this is the show and shine section so post some pics before and after and if you can during
I got mine from ACC too, but it didn't fit so great. Maybe it was my install, because I was struggling with it. I def. want to see how yours turned out though! Pics!!
Pix of interior
Sorry about the lack of pix
I added some to my album,you can see them there, but I don't know how to insert them in the thread....what can I say ..I'm an old guy, I can make the parts but can't get all this stuff figured Let me know how to , and I'll give it a try...... |
I gotta ask how on earth you got that all in there in proper working order?? I would die for awesome interior like that in my S14.
i prefer the looks on the s14 interior more then the fairlady but came out good
Sorry I've been gone for a while
The 350Z dash was just a little wider than the 240 I mocked it up, and all of the components looked like they would fit just shortened the metal cross tube from the Z, and trimmed a little plastic on both ends, then made a filler strip to fit the gap at the windshield where the curve of the glass was different. Covered that with black vinyl that matches the Z. All of the Z components " hang " from that crosstube. I kept all of the dash controls, steering column, a/c etc . The entire Z wiring harness was swapped in, and then all of the dash was plug n play. I just have two small panels to fabricate at the sides of the dash. They will be made to match the door skin profile, and will have side vents added to blow on window for defrost |
hi guys can you tell me where can i buy an s14 interior ad also a decorative interior & exterior lights for my s-chassis? ive been looking for it to change an old one. was hoping for your help.
| All times are GMT -7. The time now is 03:25 AM. |
