Digital Gauge Speedometer
I have a 1990 hatch and i've seen the digital speedometer read outs and i was wondering if and where i could get one of those.
Your gonna have to check your local junkyard and get it that or try Ebay. if you get it from the junkyard, make sure to grab the console too so everything just hooks rite up :thumb:
Digitial speedometer read out
What car and year is that off of? I need one of those badly, my speedometer doesn't work and that digital thing just looks so badass.
91-94 coupe (non FB) 240sx along witht the HUD and cluster your going need to get the little yellowish orange film that goes onto tho windshield so that you can the display. You can get this at Nissan. I have the part that displays it on the windsheild. Ill sell it cheap if you want. Your still going to need the cluster and film and your good to go. Lemme kno...
AIM: acesn8s240sx Email: JDM240sx@verizon.net or PM me :thumb: This is how the cluster looks: http://img285.echo.cx/my.php?image=untitled1sa.png http://img287.echo.cx/my.php?image=untitled24nu.png |
Sounds good, once i find the cluster i'll let you know.
1.)Do i need to get another wiring harness? I'm not to positive how the cluster is actually hooked up. 2.)If my speedometer doesn't work now is that because the cluster gauge is broken or the wiring is messed up? |
you can check the wiring but i doubt its that. Check the fuses and then take the cluster out and see if the wires. If everything is good, then your cluster is bad and will need to be replaced.
The digital cluster is the same as the one now but has only the tachometer(RPM Meter) and the HUD tells you how fast your going. The wiring is the same except for the one new wire that attaches from the HUD to the cluster. The HUD i have has the wire connected to it so all you need to do is attach it to the cluster. Hope that makes sense and helps you out :thumb: lemme kno if you need any more help. (AIM is best way to reach me) |
If you really wanna get crazy, get the digital climate control from a s13. They only came off of the cars in japan, but they are pimp. I am working on mine right now, but most of the ones you find people are selling are missing all the sensors, except for the main wiring harness for the unit. I will post up a list of all the sensors that are required that are mostly from maximas and 300zx's.
so the ones on ebay dont give the sensor?
Not usually....most of the time they just come with the gauge and the wiring sub-harness.....I think tho, that the sensors are only needed if you want to use the auto thermostat function.
yeah usually people strip them because only idiots buy things without asking questions...
