folding side view mirror
Get a generic( or model specific) mirror switch & run it from the fuse box with a relay & wire it up yourself. It isnt to hard to do. Or you can do like us manual folders do & just pull it in by hand. I mean how many times do you actually fold the mirrors in?
Well I have this information from one guy...
pull out your stock mirror switch. match it up to the jdm one. you will notice
that the jdm one has 2 extra wires, one white, one blue. get a pin pusher, and put those 2
wires into the usdm connecter. put the jdm switch in the usdm connector. run a blue wire
from the switch through the dash, then split it and run it to both mirrors. do the same
with the green wire. bam, your done. its easy, the hardest part is getting the wires through
the door jam and running them through the dash board. make sure that you zip tie the door
wires to the existing wiring harness so they dont get tangled in your window when it goes up
and down.
I need info push into the usdm connector but to which one???
and down.
whowutwut
May 19, 2008 05:09 AM
shiaokaz
Sep 29, 2004 12:47 PM
dogmantc16v
Jun 12, 2004 05:00 PM
