HELP!! Black glow gauges???
I was looking for gauges like this for my s13 (w/HUD)
Glow gauges for s13 w/HUD I was wondering if there were similar gauges but black not white. If so please let me know thanks |
it's called "reverse indiglo"
u could just throw new lights under ur stock guages...
http://memimage.cardomain.net/member...48_51_full.jpg that's on my s14, but you get the idea. www.superbrightleds.com carrys them. |
Originally posted by Waynehead05 it's called "reverse indiglo" |
I've personally never seen black indiglo guages
Originally posted by DaPCWiz [B]u could just throw new lights under ur stock guages... www.superbrightleds.com[/url] carrys them. which size led's did you use for your guages? |
http://www.superbrightleds.com/store...ges/wled-r.jpg
"WLED-R Red LED bulb 12VDC Red 1-LED Wedge Base Bulb (194/168 type)" |
Originally posted by DaPCWiz http://www.superbrightleds.com/store...ges/wled-r.jpg "WLED-R Red LED bulb 12VDC Red 1-LED Wedge Base Bulb (194/168 type)" How many do you need? |
for S14s, you need 3.
do they just plug in to the stock sockets... or do you need to modify something?
they are a direct swap. just plug and play.
sounds good. If I get time I'll call them today. Thanks
Is the stock bulb white?
Originally posted by Yeajimi Is the stock bulb white? |
will this work on an 89 240sx? non HUD
| All times are GMT -7. The time now is 03:26 AM. |
