Interchangable seats
Ok, I was wondering if the interior of an S14 could be swapped into an S13. I've seen an S13 with S14 front seats but is that custom work or just plug and play? What about the back seats too. I'm talking about a Fastback here also. Thanks for your info.
The front seats will require S13 mounts, or custom.
The rear IIRC, will take a little cutting here and there to fit correctly. So the rear isn't exactly a plug and play ordeal. |
hmmm... i can't remember what performance mag i was reading, but it said that s13-15 all use the same seat mounts, so it's plug & play. (that is, if you can /find/ s15 seats!) if you want aftermarket, custom brackets are required b/c of the 'side' mount on one of the rails, you'll end up w/ your head hittin the celing ifyou dont.
What about the dash from a s14? would that fit?
Originally posted by Texas240 hmmm... i can't remember what performance mag i was reading, but it said that s13-15 all use the same seat mounts, so it's plug & play. (that is, if you can /find/ s15 seats!) if you want aftermarket, custom brackets are required b/c of the 'side' mount on one of the rails, you'll end up w/ your head hittin the celing ifyou dont. Could be wrong:dunno: |
Cool, thanks for the info. Might be looking around for S14 leather seats.
any suggestions on wear to find s14 seats? any will do..
People who have swapped out thier seats for some sportier one, like Recaro or Bride ones.
junk yards if your luck is good, but usualy there either grimy, ripped, or theres only one side, last cause EBAY. I read from nissanperformance.com that the seats from S13- S15 all use the same brackets, so it should be fine, not sure about the back seat, anyone know if a S14 backseat would fit into a Coupe S13?
i'm keepin my s13 seats, but i'm re-upolstering everything
| All times are GMT -7. The time now is 05:03 AM. |
