Moon Roof
Old May 18, 2005 | 01:43 PM
Slidin240's Avatar
Moon Roof
I didnt kno exactly where this should be so i decided to put it in style...
I got an 89 240sx FB and i got the moonroof on it. I was checking it out and i saw that it has two locks, one next to the windshield and one near the inside dome light. I unlocked both and i pushed up and i noticed that only the lock near the light should be there... Unless the whole glass comes off. so i started working with it and in a few min i got the whole glass out. Now my question is, wtf is the 2 little plastic holder thingy for on the outlining of where the glass lays? (does that make sense?) I tried putting the glass on it but then the glass with be at an odd angle. Someone who knows about this please help me out here. Thanx
Old May 19, 2005 | 06:16 PM
jersy19's Avatar
its just a wind deflector for when the glass is off, according to the factor manual
Old May 19, 2005 | 06:31 PM
Slidin240's Avatar
do you have the factory manual??
Old May 19, 2005 | 07:21 PM
jersy19's Avatar
yea, i have a digital copy cd i got off ebay
Old May 22, 2005 | 11:14 PM
take a picture of it... but I think you're talking about the small wind deflectors, as mentioned above
Old May 23, 2005 | 06:07 AM
Atown 240's Avatar
The guy before me siliconed the sun roof to prevent leaks, but i think he got it on where the sun roof and opening meet. so when i try to open mine i cant it's stuck. How can i open it without peeling paint and without it leaking?
Old May 23, 2005 | 07:37 PM
LA_phantom_240's Avatar
do some surgery on the silicone.
Old May 24, 2005 | 06:38 AM
Slidin240's Avatar
^^ thats something easy to fix. Grab a blade and get to work. trim it little bit by little bit until you like how it is or it opens the way it should
Old May 24, 2005 | 06:40 AM
Atown 240's Avatar
what about sealing it from leaking?
Old May 24, 2005 | 06:44 AM
Slidin240's Avatar
Anyone know where i can get this?(the visor thingy)
(sorry for the big pic)
P.S. Thanx 2 Import Fanatix for the pic
Old May 24, 2005 | 06:48 AM
Slidin240's Avatar
Thats what the rest of the silicone will do when the window is closed.
Old May 24, 2005 | 01:32 PM
either thats no 240, or its a 240 with some sort of aftermarket sunroof.
Old May 25, 2005 | 01:06 PM
Slidin240's Avatar
not the sunroof, the pastic wind/bug deflector thing. i wanna get that.
(yeh its a 240 i got the pic from the Import Fanatix webpage)
Old May 25, 2005 | 02:21 PM
Chiefgmsr's Avatar
You will have to find your way to the drains witch are located near the wheels. Hint: Open sunroof. Pour H20 in the water drains. Look under car an take note where the water comes out. Get to the drain and clean it out. Usually a lot of debris. Next post on the forum where it is cuz I'm too lazy to do mine. My car isn't leakin but I figured I'd do it b4 it does. When I tried it the H20 came out right behind the front wheels, under door hinges. Note that there are also rear drains too. Goodluck!!!!
Old May 25, 2005 | 02:27 PM
Slidin240's Avatar
you got a pic of where these drains are? I see you have a 95 the rest of us that posted have S13's so isnt the Moonroof diff?
