Neon
Neon
I am looking to install a set of neon glow pedals on my '93 hatch and was wonder where the clostest (or most easily accessible) 12v source is. Any help will be much appreciated!
Originally posted by Myrkur
so no one's going to help me? your all just going to snicker and call me 'gay' or 'rice'?
u can use the cig lighter.....its not hard, all you need is basic electrical knowledge and some electracal tape
i was going to get some neon pedals....i hope you got a good deal 'cause i think the ones i was going to get were only like 20 bucks
no distraction, just a friendly under-dash glow... and they would not break because the neons are protected...
people need to think so badly, it scares me sometimes...
a friend and i installed blue neons under my dash just to see if we could....it was really easy
i dont know if yours has a switch or not, but we put a switch on my neons (i dont ever use them.....it was just a project to see if we could do it......the switch i bought at walmart) i just had to add in that walmart part 'cause i didn't know where to get a switch and i searched everywhere
if you dont know, i'll tell you how to wire it to your cig lighter
first things first, your gonna wanna disconnect your battery to make sure you dont shock the **** out of yourself
then remove your center console...but first your going to have to find all the stupid little snaps thats holding it together...theres also like 4 or 6 screws
alls you gotta do now is splice your pedals to the cig lighter
behind the cig lighter you'll see some wires covered with rubber and some insalation....cut that back and this will expose 2 wires
i'm not too sure about the colors on your car, but one should be black....and that black one should be the ground.....SHOULD BE....my car the black was the hot wire......
splice the wires....get you some electrical tape and tape that badboy up and put everything back......reconnect your battery and your in biz
if you really care i did a "how to" article on this...with pictures and all i believe
maybe you should look for it
if its not here i also posted it at altimas.net
probably under the name kackarot
i second leiferik and say that the cig lighter is a good place to wire your lights to. You can probably get a switch real cheap at a hardware store or even at like a pepboys or something and wire it in series with the neons (if you need that explained I will).
That's what I did and put the switch inside the ashtray so you can't see it (just drill a small hole in the back of the ashtray so you can get the wires through.) I just flip open the ashtray and turn on and off the lights at will. It's good to have a switch cuz sometimes the lights get annoying and you want to turn them off.
first off. the pedals use an indiglo type light element preventing crushing. second while im not a fan of the (and giant aluminum wings) that doesnt make this dude gay or a retard. just a little electricly challenged with bad taste. but anyway dude if its rigged at all like my grand nat. was the fuse pannel is prolly right down on the left near the fire wall. theres prolly an accesory plug or atleast an un-used plug where u can get 12 volts outa. otherwise do what i did with my boost gauge on my buick. rig it to the dash light dimmer switch. it'll add a little bit of extra flare (as much flare as you can have with glowy feet). but anyway it should allow you to adjust thier brightness as well.
Neon pedals... That's hilarious!
