-   -   Rims and Springs (https://www.s-chassis.com/forums/show-shine-4/rims-springs-23163/)
RS250 Chester May 27, 2005 08:52 AM
Rims and Springs
I want to eliminate the large space in the wheelwell of my 90 240.
It's completely stock, with the exception of KYB AGX shocks. Between the wheel and the fender is about 4".
What is the best way to eliminate that space. Should I go for a larger rim and tire or go with new springs. I have a feeling most will say to do both.
My goal is not to make it too low, just eliminate the space in the wheel well.
CowboyTurbo May 27, 2005 09:16 AM
seems like u've already got ur answer~ go both (new springs + wheels) if you can afford it. But I'd probably go springs first...
RS250 Chester May 27, 2005 09:56 AM
I would rather do one or the other, but not both.
Ayuaddict May 27, 2005 11:34 AM
well...in the process of eliminating wheel gap with just wheels...the larger diameter wheels will also bring your car higher off the ground....which is "technically" bad cuz the rims will be heavier (and we all kno that rotating mas is the worst kind of weight) and making your center of gravity higher (not that you can feel it....but just sayin).......the best way has to be both...but if not...springs should help get rid of that nasty wheel gap...but how do u get 4 inches?...what kind of rims u got?...my stock suspension is less than that (in the back)...and i have no tranny or engine...
RS250 Chester May 31, 2005 11:44 AM
I have the stock rims on the car.....
I'll probably do both, but yeah, I've got 4" in there.
I can fit a whole fist in the space from where the fender starts to the tire.
Levi SPL S14 May 31, 2005 02:30 PM
get coilovers then you will have no more of a problem
naptime May 31, 2005 03:03 PM
:werd: and adjust the height to your desire
Yoshi_Sil40 May 31, 2005 04:04 PM
standard AGX's are not short stroke dampers, thus going too low for extended periods will lead to premature seal failure. If you stick with the AGXs, don't drop lower than 2" (ie. sportlines are not recommended).
RS250 Chester Jun 3, 2005 11:03 AM
Do you mean, do not drop lower than 2" clearance between wheel and fender if I continue to use AGX or the new springs will need to drop the car more than 2".
If I can't use the sportlines from Eibach, can I use the ProKit? I believe the drop at the front is 1.8" and the rear is 1.6" on the ProKit.
Thanks.
