S14 Kouki Fog Lights
Old Nov 27, 2006 | 07:34 PM
Bluejayde's Avatar
If you have them, could you tell/show me where and how you turn them on? I picked up a set for my base model and don't know how to turn them on.
Just wanna know if I'm stupid or if I need to buy a switch, etc...
Old Nov 28, 2006 | 11:15 AM
ramman434's Avatar
If you didn't have the fog lights in the 1st place then you may not have a switch. On mine, the switch is on the light switch itself.
When you twist the light switch so that your headlights turn on there should be another part that you can twist just below(closer to the steering wheel) that will turn them on. They will only be on when your headlights are on though. They can't be on w/your brights or on by themselves.
Old Nov 28, 2006 | 11:27 AM
Bluejayde's Avatar
Thanks. I'm positive I don't have the right "light stick", I think I'll just wire them to the headlights so the fogs are on when the headlights are.
Old Dec 4, 2006 | 06:49 PM
get the relay for the fuse box and the se stalk. should be a plug and play matter. splicing into stock wiring is a bad idea
Indolent
Aug 10, 2006 09:08 PM
NissanS14Kid
Sep 29, 2004 11:28 AM
NiNJA323
Sep 22, 2003 06:08 AM
houston
May 25, 2003 02:37 AM
