which tail lights?
Originally posted by silviadriver
you have no idea wth your talkin about hahaha.
you just dont get LED boards off another car and place them in your car like legos. they use a different type of board than the ones you see poeple use in their corner lights
learn more about them before you tell people to do so
there has been very few poeple whom actually get a LED board working correctly like factory.
i open up lamps using the oven and do just about anything, including retrofiting led modules from trucks into taillights using pdm's and what have you.
while we are on the subject here are some tails
^^^Clear corners clear lenses...Or custom made...
Go ahead and do it...Thats not my car by the way...Ill probably end up doing it though
Originally posted by BarnDog296
That Lens trick is REALLY amazing, all I have to say is WOW, that really took me by surprise, hope you dont mind if i try it, looks JUST like the Kouki....
makes me want to change my original statement
why do you think i said retro? RETROFIT you cut up your housings, in a 240sx case remove the inner clear diffuser and silicone the modules in. i know what im talking about my friend, i have done numerous automotive lighting projects. i am working on an hid retrofit on my kouki as we speak. heres an example of what i do
Originally posted by Waynehead05
where can this lense paint be had at? i might go with the clear ricer thingy's and do that for now untill i get into body work.
you can use vinyl too it looks alot shinier and more even, try www.jmods.net and email the guy about custom sizes
it would be kinda rice unless you use vinyl from www.lamin-x.com
i wonder how it would look with the black housing instead of chrome housing....i wonder if there will be much difference....maybe the housing will reflect the light less and so u would just see red circles...
