What's The Difference guys...
Old Jul 1, 2005 | 09:06 AM
Nismo240sxDET's Avatar
Whats the difference between teh 2-door coupe and 2-door fastback?
Old Jul 1, 2005 | 09:40 AM
Slidin240's Avatar
theres a simple answer to that question....
SEARCH!!!!!!
this whole site has pics and info that can answer that question for you.
sorry to sound like a jackass but its the truth, try searching then post your questions....
Old Jul 1, 2005 | 09:59 AM
Sil40_Mayhem's Avatar
start in the FAQ section.
Old Jul 1, 2005 | 03:23 PM
i still cant find anything....
Old Jul 1, 2005 | 03:45 PM
Slidin240's Avatar
try looking at some pics maybe that will help
Google search 240sx coupe, 240sx hatch, etc
BTW: i just dont believe that searching didnt get you any answers.
Old Jul 1, 2005 | 04:36 PM
Jack The GTR's Avatar
jesus........just answer his question
one is a hatchback also known as the 180sx in japan.
the other is a coupe (no rear hatch) known as a one-via in japan BUT with a silvia conversion the rules change
the hatchback becomes a sil-80
the coupe becomes a silvia
i hope i did okay
Old Jul 1, 2005 | 04:44 PM
the only difference i seen was the tailights are different and one has a trunk and one has a hatch but is the performance wise anything differnt or both the same performance wise....
Old Jul 1, 2005 | 04:47 PM
the coupe is alot lighter due to no rear glass like the hatch.same engines
Old Jul 1, 2005 | 04:55 PM
i perfer the fastback...
besides the coupe being lighter and not having a hatch, there are no performance differences
Old Jul 1, 2005 | 06:52 PM
Cape 240's Avatar
i think the central balance of the weight is different too.
I think the fastback is damn close to 50/50 but the coupe is like 60/40??
I could be wrong. Which is why the fastback is preffered for drifting.
Old Jul 1, 2005 | 07:13 PM
lrb_2000's Avatar
Coupe = 2699lbs
Fastback = 2730lbs
There's only a 30lb difference... I wouldn't worry about it... If I were buying a 240sx, I would go by which one you think looks better... you won't notice any perfomance difference in either stock.
For SE models add about 35lbs more to that due to A/C and power options/sunroof.
Old Jul 3, 2005 | 07:51 PM
ArticDragon's Avatar
The coupe is lighter. The Fastback has more cargo room and has a weight distribution closer to 50/50.
Old Jul 3, 2005 | 08:28 PM
S13 Coupe:
S13 Hatch:
S14 (coupe only):
Old Jul 7, 2005 | 12:21 AM
os_carlover's Avatar
f$#k all those . what you have to do is get a 95 or higher. i started with a 89 fastback, then traided it fit 92 coupe, then crashed that and ended up with 90 fastback and now i am with a 95. and i have never been hapier
