S14 Auto ECU, Driveshaft, Pulleys, Door Panel, Suspension, Antenna, Intake Pipe &MORE
Old Jan 19, 2009 | 07:24 AM
Bernie (NoVA)'s Avatar
Smile S14 Auto ECU, Driveshaft, Pulleys, Door Panel, Suspension, Antenna, Intake Pipe &MORE
All parts from 1997 S14 w. just 82k miles unless otherwise noted.
All prices INCLUDE shipping - if you think they are too high make me a counter offer.
If you are in the Washington DC / NoVA area you're welcome to pick up as well.
ADDED:
Complete Set Z32 front & rear brake shims $30
Kicker 8" Sub Tube $75
JDM S14 Black Silve Hood & Trunk Badges
$20 each or $35 pair
KA S14 1998 AC Compressor $75
Auto Driveshaft w. support brace (not pictured)
Center bearing intact & solid.
$40
E-Brake Cables
$20 / pair
S13 Washer fluid bottle w. neck & pumps
$25
Z32 LSD output flanges (from 91 300zx w. ~65k miles)
$25 / pair
Horn & temp sensor clipping
$8
SE Front Swaybar
$25
Hood gasket set (fits 95-98)
$15
Fuse box lid $10
Door triangles SOLD
Z32 Compact (aluminum) spare & 1 can of co2 tire inflator (not junk fix-a-flat) $95
Will clear Z32 front or rear calipers of course.
Auto Shifter Assembly
$20
Complete pulley set w. crank pulley
$30
Stock SE shocks (springs already sold)
$35
Radiator air guides
$15 / set
ECU late 97-98, KA24DE auto
$45
Auto trans Controller ECM 97-98
$25
Rubber bits
Radiator mounts / 4 $7
Shock tower caps SOLD
Front Diff bushings /2 $7
Exhaust cat hanger
$10
Intake Tube w. support bracket (bracket not in picture but is included)
$15
Zenki fog light connectors (used w. tested & working bulbs)
$15 / pair
Zenki Intake Air temp sensor w. bracket
$8
Thanks for looking
Energy Suspension bushings for front or rear sway end links SOLD
Door Panel SOLD
Kouki Headlight Connector SOLD
Gorrilla slim line lug nuts & lock set SOLD
Door triangles SOLD
Intake Tube Coupler SOLD
Front tension rod brackets SOLD
ECU late 95-96, KA24DE auto SOLD
KA S14 1998 Alternator SOLD
AC lines & dryer SOLD
Manual Antenna Base SOLD
Zenki Intake Air temp sensor SOLD
Old Jan 24, 2009 | 03:03 PM
94 sentra_xe's Avatar
ill take the ES bushings
Old Jan 25, 2009 | 09:47 AM
Cool - sending you a PM w. payment info.
Old Feb 3, 2009 | 07:11 AM
Bushings Sent
U.S. Postal Service 9101128882300590941102
Updated listing w. currently available items.
Old Feb 3, 2009 | 12:00 PM
wow that was fast, great seller!
Old Mar 1, 2009 | 10:46 AM
Citille's Avatar
Fuse Box Lid
Interested in the fuse box lid if still available. Let me know, Thanks
Old Mar 1, 2009 | 06:33 PM
Yes the lid is available.
Sent you a PM w. PayPal info.
Thanks.
Old Apr 25, 2009 | 07:53 AM
stettearile's Avatar
Re: ìóòàíòêè òîæå õî÷óò: ïîñìîòðåòü ïîðíî ñåé÷àñ.
ìàëåíüêèõ äåòåé ÷àñòíîå ñåìåéíîå ýðîòè÷åêîå ôîòî ðàñïèñàíèå àâòîáóñà âîëãîãðàä äîìàøíèé ïîðíî ôîòîãðàôèè àòü ïîðíî âèäåî ÷àñòíîå ëþáèòåëüñêîå äîìàøíåå ïîðíî ôîòî ñêà÷àòü äîìàøíèé ïîðíî ôîòîãðàôèè áåñïëàòî ïîðíî.
ïîðíî ñòàðûå òðàõàþò ìîëîäûõ ñìîòðåòü.ðàññêàçû ïîðíî ôîòî äîìàøíèé ïîðíî ôîòîãðàôèè ìàëî.
ïðî ñåêñ ðåä÷àéøåå ïîðíî ñàìáóêà ïîðíî ìèëÿâñêàÿ ïîðíî äîìàøíèé ïîðíî ôîòîãðàôèè êóíèëèíãóñ ôèëüìû ïîðíî ãîëîä ñåêñ âèäåîðîëèêîâ.ôîòî ãîëûå.
êíèãà ñêà÷àòü äîìàøíèé ïîðíî ôîòîãðàôèè àäðåñà ñåêñóàëüíûõ íî÷íûõ êëóáîâ â ãîðîäå ìîñêâû ñåêñ áåç äîìàøíèé ïîðíî ôîòîãðàôèè îãðàíè ñåêñ ôîòî ñòþàðäåññ æåñòêèé ñåêñ èçíàñèëîâàíèå æåñòêîå ïîðíî ñåêñ áåëàðóñü.
ýðîòèêà ôîòî.
Ìóòàíòêè òîæå õî÷óò: äîìàøíèé ïîðíî ôîòîãðàôèè.
Õî÷åøü òðàõíóòü òåëêó ñ õâîñòîì? Ìóòàíòû òîæå òðàõàþòñÿ!
Òû çàìîòàåøüñÿ êà÷àòü ïîðíî âèäåî ñ íàøåãî ñàéòà! Õî÷åøü ïîñïîðèì?
Òàê ìíîãî ïîðíî ôèëüìîâ òû åùå íå âèäåë! À ðàçíîîáðàçèå íèø òåáÿ ïðîñòî øîêèðóåò!
Ïðåäïî÷èòàåøü þíûõ êðàñîòîê ñ òîð÷àùèìè ãðóäêàìè? À, ìîæåò, îïûòíûõ çðåëûõ äàìî÷åê, êîòîðûì ïàëåö â ðîò (èëè åùå êóäà ) íå êëàäè? Èëè, âñå-òàêè, æåñòîêèå èãðû, ïðè÷èíÿþùèå áîëü? ×òî áû òû íå âûáðàë, çäåñü òû íàéäåøü âèäåî äëÿ ñåáÿ!
×òî èëè êòî òåáÿ áîëüøå âñåãî âîçáóæäàåò? Ìèëûå äåâî÷êè, êîòîðûå çàñàñûâàþò è ñåäëàþò ìàññèâíûå ÷ëåíû? À, ìîæåò, èõ ïîäðóæêè, êîòîðûå âûëèçûâàþò âëàæíûå êèñêè? Èëè ìàòåðûå áàáåíêè, êîòîðûå òðàõàþòñÿ êàê â ïîñëåäíèé ðàç? Íåò? Òû õî÷åøü ïîñìîòðåòü íà èãðû ìóñêóëèñòûõ ïàðíåé? Äàæå åñëè òåïåðü òû îòâåòèë íåò, áóäü óâåðåí, ÷òî íà íàøåì ñàéòå íàéäóòñÿ ïîðíî ôèëüìû è äëÿ òåáÿ!
Íèêòî åùå íå ñäåëàë ýòîãî – íå ïðåäëîæèë òåáå äîñòóï ê òûñÿ÷àì ïîðíî ôèëüìîâ â ñàìûõ ðàçíûõ êàòåãîðèÿõ èç îäíîãî ìåñòà! À ìû ïîñòàðàëèñü è ñîáðàëè ó ñåáÿ ðåàëüíî ëó÷øèå ôèëüìû ñ ëó÷øèìè ïîðíîçâåçäàìè è ïðîñòî îáû÷íûìè ïàðíÿìè è äåâ÷îíêàìè, êîòîðûå îáîæàþò òðàõ âî âñåõ åãî ïðîÿâëåíèÿõ!
Íî òåïåðü íå íóæíî çàìîðà÷èâàòüñÿ! Ýòî òåïåðü ðåàëüíîñòü! Òû áåç îñîáîãî òðóäà ïîïàäåøü íà îäèí ñàéò è îòòóäà ñìîæåøü çàêà÷àòü áåñ÷èñëåííûå ãèãàáàéòû ñóìàñøåäøåãî ïîðíî âèäåî â ëþáîé íèøå! Ìû ïîâòîðÿåì – ëþáîé! Íå òðàòü íè ìèíóòû, êà÷àé!
Òåïåðü ïîÿâèëñÿ ÎÍ – ìåãà-ïîðòàë, ãäå ñîáðàíà ëó÷øàÿ êîëëåêöèÿ ïîðíî ôèëüìîâ âî âñåõ ìûñëèìûõ è íåìûñëèìûõ êàòåãîðèÿõ. Îäèí ñàéò, îäèí ïàðîëü è òûñÿ÷è ðàçðûâíûõ ïîðíî ôèëüìîâ! Ýòî ëè íå ðàé?
Old Apr 25, 2009 | 10:27 PM
240smoke's Avatar
Hmm.... This could be spam. Not sure yet.
Old May 11, 2009 | 08:59 PM
is that 2 vag's?
Bernie (NoVA)
For Sale - Suspension / Brakes / Handling
Apr 3, 2012 07:34 AM
ONYX S-13
Jul 7, 2006 07:58 AM
Carparthookup
Aug 11, 2005 12:14 PM
TM180sx
Jun 22, 2005 09:12 PM
vcs2340
Aug 21, 2004 11:52 AM
