Trouble Installing Megan Exhaust Manifold *VIDEO INCLUDED*
Old 05-08-2011, 04:56 PM
bootscut's Avatar
Hi Guys,
I have a S13 SR20 blacktop and I am having a lot of trouble fitting the megan exhaust manifold. For some reason the turbo elbow gets in the way (a lot) so I am not able to fit the manifold to the hot end of the turbo. I hope this makes sense, if anyone has any experience installing manifolds please message me!
http://www.youtube.com/watch?v=B77DOBbGIS0
bootscut
bootscut is offline
Old 05-08-2011, 05:50 PM
crazydrifter's Avatar
wierd... i had the same manifold on my blacktop when i had one and it fit perfect... hope you figure it out!
crazydrifter is offline
Old 05-08-2011, 06:05 PM
bootscut's Avatar
yea =/ a lot of guys are saying that I just need to clock the turbo to point it downwards, not sure if I will need some extra parts/material by going that route
bootscut is offline
Old 05-09-2011, 06:41 AM
maybe an extra coupler or inter-cooler pipe but thats about it, no biggie!
Old 05-21-2011, 01:35 PM
driftapimp's Avatar
clock turbo away from mani and it should fit to a normal fmic kit
driftapimp is offline
Old 05-21-2011, 02:26 PM
your turbo looks wrong for some reason
i know this is a new turbo and a different manifold with no elbow but by looking at it you can tell adding a elbow wont interfere with the manifold.
yours just dosnt look aligned right
battosaii930 is offline
Old 05-21-2011, 02:57 PM
bootscut's Avatar
Hey guys thanks for the replies! I ended up fixing it, in case anyone has this issue again heres a very simple fix:
There is a snap ring located in the compressor housing of the turbo, so that part that kept getting in the way can easily be rotated left or right if you use a good set of needle nose pliers to squeeze the snap ring and then simply rotate the turbo
bootscut is offline
s13slider44
05-20-2006 01:10 PM
95-2froties
02-12-2006 08:35 PM
reisg
09-16-2005 11:05 PM
S13Ka24deTuRbO
02-08-2005 09:04 PM
Heely
10-26-2003 02:46 PM
Quick Reply: Trouble Installing Megan Exhaust Manifold *VIDEO INCLUDED*
