Help
Old Apr 5, 2008 | 07:35 PM
S14kidd's Avatar
Help
okay i was driving my car and it just shut off....I checked the fuel pressure and i was getting no fuel so i checked all the fuses and relays and those were all still okay so i went ahead and changed my fuel pump and still luck...What else can it be?
Old Apr 5, 2008 | 07:55 PM
HKST04Z's Avatar
big vaccume leak?
Old Apr 5, 2008 | 09:23 PM
S14kidd's Avatar
im gonna check if im getting power to the pump in the morning
Old Apr 5, 2008 | 10:43 PM
well a vacuum leak would not get you anywhere... Fuel is Electronically injected.
what you need to do is run a ecu diagnostic that could tell you some vital info..
from my experience this could be a few things:
-ecu itself which contains injector drivers
-faulty Crank Angle Sensor
-damage fuel pump terminals
-Relay
when you turn your key to the ACC position, can you hear the fuel pump prime the injectors at all????
to test your CAS quickly, loosen it... turn the car to the ACC position.. mark your CAS position. and slowly rotate left fully and right. you should hear the injectors Click. if they do, you can rule out the CAS and ecu as the issue and focus on a relay or faulty fuel pump terminal...
hope that helps a bit.
Old Apr 6, 2008 | 11:46 AM
S14kidd's Avatar
Figured out It was my ECU..also my motor was not grounded correctly
Old Apr 6, 2008 | 12:48 PM
YAY for the win.... whats my prise bro...
jk
good stuff man
Old Apr 6, 2008 | 06:03 PM
S14kidd's Avatar
lol thanks for the help man
Old Apr 15, 2008 | 10:36 PM
S14kidd's Avatar
s14 no fuel
we checked all the fuses and repleaced all relays and replaced the fuel pump.it something in the wiring we cant figure it out.maybe you guys can help
sr20det red top and we also got a new ecu
leiferik1
Oct 13, 2002 08:45 PM
