parts crossover
taken from various forums
Exhaust Manifold Gasket '91 Sentra SE-R w/SR20DE
T25 Turbo gaskets '90-'95 300ZX TT T25 gaskets (note turbo to O2 housing gasket dose not fit on S13 T25)
O2 sensor '87 300ZX Turbo
Ignitor chip '95 Q45
Fuel Injectors '95 300ZX TT (purple plugs)
Fuel Injector Seals '95 300ZXTT kit
MAF '89-'90 SOHC 240SX
Tranny rear main seal '93 240sx
Slave cylinder '93 240sx
T.O. bearing '93 240sx
Pilot bearing '93 240sx
Clutch 89 Nissan Maxima 240mm 9-7/16" spline 24x1
Belts (PS, AC, alt) Gates K050370 Alt. K040345 PS & AC
Spark Plugs NGK BKR7ES11 or BKR6 (hoter plug)
Coil Packs '90-'95 300ZX or '95 newer Maxima
S14 SR Oil Filter '95 Sentra SE-R
S13 SR Oil Filter '91 Sentra SE-R
Fuel filter '90 300zx TT
Front and Rear main seal '91 SE-R
TPS '95 KA TPS will work with some soldering
Temp sensor S13 or S14 (depending on chassis not motor) KA24DE temp sensor
Thermostat '91 Sentra SE-R
Radiator cap '90 300zx TT (slightly more pressure for better cooling over stock cap)
Knock sensor '95 240sx
Oil pressure sender '95 240sx
The only parts you really need to get from Japan are the starter, alternator, water pump, and headgasket. Most everything else can be found locally or adapted to fit.
more
Part type
Nissan Australia part number
Other source or comments
Oil filter
15208-H8911
Ryco Z145A (CA18 all?)
Door bump rubbers
01658-J7000 (Skyline R31)
Exhaust manifold gasket
14036-D4200 (EXA 1.8, S13 CA18)
Four separate pieces
Intake manifold gasket
14035-D5710 (CA18 all)
Injector rail to cylinder head
14035-D5711 (CA18 all)
Injector rail to intake runner
14035-53J10 (SR20 all)
Turbo inlet flange gasket
14415-75F10 (200SX)
or 14415-17M00 (S13 all)
The Aust 200SX one fits.
Turbo outlet flange gasket
14445-26E00 (S13 all)
Engine front oil seal
13042-42L00 (CA18 all)
Engine rear oil seal
12279-18V00 (CA18 all)
Oil pan seal front
11121-01F10 (CA18 all)
Oil pan seal rear
11121-01F15 (CA18 all)
Head gasket
11044-51E00 (CA18 all)
Head gasket
11044-50F00 (SR20)
until 9/92
Head gasket
11044-50F01 (SR20)
from 9/92 till 7/93
Head gasket
11044-50F10 (SR20)
from7/93 onwards
Engine gasket kit
10101-51E25 (CA18D)
Engine rebuild gasket kits
Engine gasket kit
10101-56E25 (CA18DET)
Engine gasket kit
10101-50E25 (SR20DET)
Engine gasket kit
10101-51E26 (SR20D)
Valve grind gasket kit
11042-51E25 (CA18 all)
11042-50F25 (SR20 all)
Fan belt
11720-V7301 (CA18 all)
L = 855mm
Fan belt
11720-52F00 (SR20 all)
Compressor belt
11920-V7301 (CA18 all)
also suits power steering pump
Compressor belt
11920-30R10 (SR20 all)
Water pump
21010-V5528 (CA18)
until 8/90
Water pump
21010-V5529 (CA18)
from 8/90
Water pump
21010-52F00 (SR20 all)
Thermostat
21200-V0201 (CA18 all)
82.0 C
Thermostat
21200-V0206 (CA18 all)
88.0 C
Thermostat
21200-53J00 (SR20 all)
Radiator cap
21430-01F01
Radiator hose - upper
21501-35F10 (CA18 all)
Radiator hose - lower
21503-35F00 (CA18 all)
21501-52F00 (SR20 all)
21503-52F00 (SR20 all)
Bonnet bump rubbers (large)
62840-D0100 (Skyline R31)
Engine coolant
10120-89904
Castrol
Dash switch back lights
Nissan Aust, have similar types
$11.00 each
**** Smith P8130, with fiddling needed or 12v lamps WT2-12 from WES Components, good fit. 65c each
Radius rods (Tension rods)
54468-35F20 (S13 all) includes bush
Genuine Nissan imports (JSVA), Remanufactured with Urethane (Cars of Saigon ).
Wheel nut
62840-21001 (R31 Skyline)
Brake pads
See service info page.
Bendix and others.
Headlight globe
Who cares
Any brand. H4 60/55W 12V or H4 100/55W 12V the second one has 100Watt high beam.
Rear Dampers
( shockers )
See Nissan Dealer or Nismo
KONI. Part no. 80-401-081 sports kyb.
Approx $315 a pair.
Fuel filter
16400-F5100 (CA18 and SR20)
RYCO Z202
Air Filter
16546-V0100 (same as R31 Skyline)
K&N high flow reusable type P/N 33-2031-1
Spark plugs
22401-58S16 (PFR6A11, CA18)
Non resistor type NGK BCP6ES11 (11 = gap of 1.1mm)
Spark plugs
22401-53J16 (PRF6B, SR20DET)
Crank angle sensor
23731-85M10 (CA18 all)
Crank angle sensor
23731-50F01 (SR20 all)
Coolant temp sensor
25080-89903 (S13 all)
Oil pressure sender
25240-89920 (S13 all)
more
Part type
Oil filter
15208-H8911
Door bump rubbers
14415-75F10 (200SX)
Oil pan seal front
Oil pan seal rear
Head gasket
Head gasket
11044-50F00 (SR20)
until 9/92
Head gasket
11044-50F01 (SR20)
from 9/92 till 7/93
Head gasket
11044-50F10 (SR20)
from7/93 onwards
Engine gasket kit
10101-51E25 (CA18D)
Engine gasket kit
Engine gasket kit
Engine gasket kit
10101-51E26 (SR20D)
Fan belt
L = 855mm
Fan belt
Compressor belt
Compressor belt
Water pump
21010-V5528 (CA18)
until 8/90
Water pump
21010-V5529 (CA18)
from 8/90
Water pump
Thermostat
82.0 C
Thermostat
88.0 C
Thermostat
Radiator cap
21430-01F01
Engine coolant
10120-89904
Castrol
$11.00 each
Wheel nut
Brake pads
Bendix and others.
Headlight globe
Who cares
Rear Dampers
( shockers )
Approx $315 a pair.
Fuel filter
RYCO Z202
Air Filter
Spark plugs
Spark plugs
Crank angle sensor
Crank angle sensor
Coolant temp sensor
Oil pressure sender
yea i heard a kade alternater will fit you just have to drill one of the holes out i was hopin the starter was the same cuz damn they are expensive as hell and mine grinds when i start it i wonder if i can just get mine rebuilt
Juiced
04-29-2008 05:32 PM
Will fastback S
09-22-2005 09:16 AM
iroc07
08-29-2004 04:09 AM
