turbo question
Old 01-21-2011, 05:24 PM
turbo question
well i have a gt2871r with the oem looking housing that bolts right on to an SR.
i just got a screamer pipe and they have a divider that divides wastegate and exhaust gases.
ok my problem is that the turbo i have already has a divider in it so the screamer pipe wont bolt on to it unless i remove the the divider from the pipe.
well i did that and the divider on the turbo dosnt completely seal so sounds like i got exhaust leak.
my question is would it be advisable to grind down the divider on the turbo to make it work?
that would be a quick fix or i can spend half the day and grind the divider on the pipe until it fits flush with the divider on the turbo.
ah just getting ideas and seeing if anyone had run into this problem
battosaii930 is offline
Old 01-26-2011, 10:39 AM
can you double up on gaskets? If not, I would grind down the divider
silviaks2nr is offline
Couped_up'd
04-18-2009 04:42 AM
rkcarguy
06-26-2004 11:28 PM
NOS_is_4_cheat
01-11-2004 09:28 PM
Jonas
05-24-2003 02:10 AM
nissmo240sx
12-10-2002 08:31 PM
Quick Reply: turbo question
