parts crossover
Does anybody have a list of parts in the us that will work with an sr20det, Ive seen one before but i cant find it now, yes i searched
taken from various forums
Exhaust Manifold Gasket '91 Sentra SE-R w/SR20DE T25 Turbo gaskets '90-'95 300ZX TT T25 gaskets (note turbo to O2 housing gasket dose not fit on S13 T25) O2 sensor '87 300ZX Turbo Ignitor chip '95 Q45 Fuel Injectors '95 300ZX TT (purple plugs) Fuel Injector Seals '95 300ZXTT kit MAF '89-'90 SOHC 240SX Tranny rear main seal '93 240sx Slave cylinder '93 240sx T.O. bearing '93 240sx Pilot bearing '93 240sx Clutch 89 Nissan Maxima 240mm 9-7/16" spline 24x1 Belts (PS, AC, alt) Gates K050370 Alt. K040345 PS & AC Spark Plugs NGK BKR7ES11 or BKR6 (hoter plug) Coil Packs '90-'95 300ZX or '95 newer Maxima S14 SR Oil Filter '95 Sentra SE-R S13 SR Oil Filter '91 Sentra SE-R Fuel filter '90 300zx TT Front and Rear main seal '91 SE-R TPS '95 KA TPS will work with some soldering Temp sensor S13 or S14 (depending on chassis not motor) KA24DE temp sensor Thermostat '91 Sentra SE-R Radiator cap '90 300zx TT (slightly more pressure for better cooling over stock cap) Knock sensor '95 240sx Oil pressure sender '95 240sx The only parts you really need to get from Japan are the starter, alternator, water pump, and headgasket. Most everything else can be found locally or adapted to fit. more Part type Nissan Australia part number Other source or comments Oil filter 15208-H8911 Ryco Z145A (CA18 all?) Door bump rubbers 01658-J7000 (Skyline R31) Exhaust manifold gasket 14036-D4200 (EXA 1.8, S13 CA18) Four separate pieces Intake manifold gasket 14035-D5710 (CA18 all) Injector rail to cylinder head Intake manifold gasket 14035-D5711 (CA18 all) Injector rail to intake runner Intake manifold gasket 14035-53J10 (SR20 all) Turbo inlet flange gasket 14415-75F10 (200SX) or 14415-17M00 (S13 all) The Aust 200SX one fits. Turbo outlet flange gasket 14445-26E00 (S13 all) Engine front oil seal 13042-42L00 (CA18 all) Engine rear oil seal 12279-18V00 (CA18 all) Oil pan seal front 11121-01F10 (CA18 all) Oil pan seal rear 11121-01F15 (CA18 all) Head gasket 11044-51E00 (CA18 all) Head gasket 11044-50F00 (SR20) until 9/92 Head gasket 11044-50F01 (SR20) from 9/92 till 7/93 Head gasket 11044-50F10 (SR20) from7/93 onwards Engine gasket kit 10101-51E25 (CA18D) Engine rebuild gasket kits Engine gasket kit 10101-56E25 (CA18DET) Engine gasket kit 10101-50E25 (SR20DET) Engine gasket kit 10101-51E26 (SR20D) Valve grind gasket kit 11042-51E25 (CA18 all) Valve grind gasket kit 11042-50F25 (SR20 all) Fan belt 11720-V7301 (CA18 all) L = 855mm Fan belt 11720-52F00 (SR20 all) Compressor belt 11920-V7301 (CA18 all) also suits power steering pump Compressor belt 11920-30R10 (SR20 all) also suits power steering pump Water pump 21010-V5528 (CA18) until 8/90 Water pump 21010-V5529 (CA18) from 8/90 Water pump 21010-52F00 (SR20 all) Thermostat 21200-V0201 (CA18 all) 82.0 C Thermostat 21200-V0206 (CA18 all) 88.0 C Thermostat 21200-53J00 (SR20 all) Radiator cap 21430-01F01 Radiator hose - upper 21501-35F10 (CA18 all) Radiator hose - lower 21503-35F00 (CA18 all) Radiator hose - upper 21501-52F00 (SR20 all) Radiator hose - lower 21503-52F00 (SR20 all) Bonnet bump rubbers (large) 62840-D0100 (Skyline R31) Engine coolant 10120-89904 Castrol Dash switch back lights Nissan Aust, have similar types $11.00 each **** Smith P8130, with fiddling needed or 12v lamps WT2-12 from WES Components, good fit. 65c each Radius rods (Tension rods) 54468-35F20 (S13 all) includes bush Genuine Nissan imports (JSVA), Remanufactured with Urethane (Cars of Saigon ). Wheel nut 62840-21001 (R31 Skyline) Brake pads See service info page. Bendix and others. Headlight globe Who cares Any brand. H4 60/55W 12V or H4 100/55W 12V the second one has 100Watt high beam. Rear Dampers ( shockers ) See Nissan Dealer or Nismo KONI. Part no. 80-401-081 sports kyb. Approx $315 a pair. Fuel filter 16400-F5100 (CA18 and SR20) RYCO Z202 Air Filter 16546-V0100 (same as R31 Skyline) K&N high flow reusable type P/N 33-2031-1 Spark plugs 22401-58S16 (PFR6A11, CA18) Non resistor type NGK BCP6ES11 (11 = gap of 1.1mm) Spark plugs 22401-53J16 (PRF6B, SR20DET) Crank angle sensor 23731-85M10 (CA18 all) Crank angle sensor 23731-50F01 (SR20 all) Coolant temp sensor 25080-89903 (S13 all) Oil pressure sender 25240-89920 (S13 all) |
that site is nice man, they have good straight forward right ups, i used it to help a buddy before.
thanks man i think we should sticky this list
so theres no starter that can work with it?
na that part you have to source that from japan. it has a funny style starter..
the teeth pop out when you hit the ignition and retracts back in after the car is started. |
yeah tha Starter has to be straigh up from Nihon but I've heard of customizing other alternators to fit on the SR. I plan on doing that.
yea i heard a kade alternater will fit you just have to drill one of the holes out i was hopin the starter was the same cuz damn they are expensive as hell and mine grinds when i start it i wonder if i can just get mine rebuilt
im sure someone can rebuild it for you locally or something
or just find one in the junkyard.
