stock temp gauge stop working
Old Jun 11, 2009 | 09:33 PM
ayoitbephil's Avatar
So my stock temp gauge decided to stop working on my sr so any ideas out there to fix it? One thing i was thinking was to put an adapter onto the upper rad hose, and doing it that way but i think its not the best way to do it.
Old Jun 11, 2009 | 10:52 PM
positron's Avatar
Stupid question but did you check the connections?
Old Jun 12, 2009 | 04:25 AM
check the stock temp sensor terminal.. they corrode and break off alot.
you can't utilize an aftermarket temp sensor with OE...
Old Jun 12, 2009 | 07:04 AM
just wondering where it is located on the sr?
Old Jun 12, 2009 | 08:01 AM
Old Jun 12, 2009 | 09:05 AM
um.. Donnie thats soposed to be a bleeder screw not a temp sensor >.>
Old Jun 12, 2009 | 09:36 AM
yea i know it suppose to be but many people run them to there. i dont own an sr nor have I worked on one in relation to temp sensors. i have seen many of them run there.
Old Jun 12, 2009 | 10:20 AM
I've checked mines but theres nothing there.
Old Jun 12, 2009 | 10:30 AM
nvm found the screw but seems like the bleeding screw hole is kinda small if i were to put and aftermarket water temp sensor in there.
Old Jun 12, 2009 | 11:25 AM
it is a bleeding screw.
there are 2 temp sensors on the SR one for the gauge and one for the ECM.
they are above the throttle body pretty close to each other. the one to the left is the temp sensor for the gauge
Old Jun 12, 2009 | 01:40 PM
can i replace the one on the left for an after market one? and not use the stock one?
Old Jun 13, 2009 | 09:28 AM
positron's Avatar
Yes! I would highly recommend it as the stock temp gauge is horrible. I've had people tell me that their aftermarket temp gauges were well above 200 while the stock gauge still read normal. Absolutely horrible!
Old Jun 14, 2009 | 02:45 PM
so i can rip out the stock temp sensor and in replace put the after market one in there? and if so would the aftermarket temp fit in their?
Old Jun 14, 2009 | 08:43 PM
240smoke's Avatar
As long as the thread pitch is the same, it will fit. Alot of people buy the S14 coolant neck and put an aftermarket temp sensor in it.
If the thread pitch isnt the same, you can get an adapter for it.
Old Jun 14, 2009 | 10:19 PM
positron's Avatar
If you get a S14 waterneck you can use an adapter like this to install your water temp sensor into.
These are the adapters that come with an Autometer water temp gauge...
unfortunately none of them fit the bung...
so I got this adapter from JEGS part#:100460 1/4" male to 1/8' female
Works perfectly and doesn't leak. Hook it up!
It's also one of the cheapest options as the aftermarket hose with bung in it is over $100 and the water neck adapters will cost you about $10 to $15 more than a S14 waterneck and this JEGS adapter although the S14 waternecks have gone up in price since I got mine....curious!?
