1989 240sx coupe LSD?
Re: 1989 240sx coupe LSD?
Originally posted by war
How can I figure out if I have LSD?
Originally posted by camrytrd93
what lsd rear can be put in a 240 coupe with non lsd ? what car would i get one from, 300zx ?
):USDM S13 HICAS edition
Canadian S13 (91+)
S14 SE (w/LSD option; may require different output shafts and whatnot)
JDM S13
Infiniti J30 (there's something about ABS and the driveshaft, IIRC)
N/A Z32 300ZX (the TT 300ZX has a longer gear ratio than the N/A)
basically, the part number ur looking for is the R200V differential (which all of the above vehicles should have). as i said before, some are a direct bolt on, some require things like: different dff cover, output shafts, driveshafts, ABS input rings, etc. i don't know which model needs what. there are FAQ's and howto's on the net about doing the diff swap and they're easy to find. plus, they usually have all that extra info about the swap. hope this helps.
