Is the 5 lug conversion necessary?
What is the purpose of the 5 lug conversion? Is it just to be able to fit rims that might not come in 4 lug or is there another reason?
been ask so many times
5lug is for OFFSET/WIDTH selection. thats the only reason |
When you say selection do you mean you can fit bigger widths or you have a bigger selection of wheels?
Can't you also get a big brake kit with a 5 lug and not a 4 lug? |
Search my friend....
Originally posted by h22lude When you say selection do you mean you can fit bigger widths or you have a bigger selection of wheels? Can't you also get a big brake kit with a 5 lug and not a 4 lug? like i said its width and offset selection. wheel companie smake wheels in 4/5 lug. |
Having a 5 lug means better wheel selections.
IE: It's hard to find a 17x9.5 +15 in a 4 lug.. |
4 lugs are usually for FWD applications so the majority of the wheels` offsets and widths arnt suitable for RWD cars...u can use them but theyre pretty gay...and since most RWD cars that are "performance oriented" come with 5 lugs...aftermarket wheelmakers make the wider width/lower offset wheels in 5 lug to save production costs by making those sizes available only in 5 lug...that should make sence to you
Originally posted by silviadriver usually id flame the hell outta poeple by now for makign two threads in which can be foudn by easy searching. and being a newbie doesnt void you from searching like i said its width and offset selection. wheel companie smake wheels in 4/5 lug. |
basically...better wheels,better offsets so you dont get the sunken in look. and some other things
Originally posted by h22lude Then go ahead and flame. |
you also dont have to have rotors re-drilled if you put on Q or Z32 brakes.
Originally posted by phreze LOL, this could get interesting. I am not trying to start anything I just hate when people say search. I have been posting on forums for 5 years so I know how they work. I do search and if I can't find what I am looking for I ask. Maybe I used the wrong words to search with and someone has a better phrase to use and that is why I ask. Even if this was my first post on any forum, answer the question and tell me that searching might get your answer without waiting for someone to reply. If they want to ask the question anyway, let them. If you don't like it then don't reply to it. Back on topic, so basically a 5 lug conversion is worth it because you can get rims to fit to the car instead of having rims that are sunk in and don't look as good |
Originally posted by h22lude I am going to ask the questions that I can't find the answer by searching. Originally posted by h22lude Maybe I used the wrong words to search with and someone has a better phrase to use and that is why I ask. Originally posted by h22lude Even if this was my first post on any forum, answer the question and tell me that searching might get your answer without waiting for someone to reply. If they want to ask the question anyway, let them. If you don't like it then don't reply to it. Originally posted by h22lude Back on topic, so basically a 5 lug conversion is worth it because you can get rims to fit to the car instead of having rims that are sunk in and don't look as good but hey i got a present for you. http://www.club240.com/forums/showth...highlight=5lug http://www.club240.com/forums/showth...highlight=5lug so ask yourself, did you really search hard enough? you can call me king, daddy, or pimp. but king will do. |
do 5 lug.
then read the stickies at the top so you know why you did it. done. |
you didn't search hard enough. And I'm not being a dick about it either.
Answer - 5 lug, better offsets. That means no Honda-type +45 FWD stuff. CLOSED |
