Alignment question
I replaced the shocks and coils on my car(1996 s14) car over a month ago. i noticed when i replaced them, all the boots were deteriorated and the insulators were worn through on one end. i bought new boots and plan on installing them when i get some more parts so i can give it a one shot fixes everything day.
where can i get the coil spring insulators(the sleeve type isolator things that go on top and bottom of the spring when connecting it to the strut/mounting plate? i searched kragen, autozone and pepboys and came up empty... how much can i expect to pay? http://www.ingallseng.com/parts/81250.htm i need to get adjustable camber bolts for my lowered car, sitting on sportlines and the front camber is totally negative. has anybody bought these for their car? if so, do they fit well? pdm racing quotes that the 95-98 needs 14mm bolts but ingalls lists 12mm... |
So i bought the 12mm ingalls camber bolt kit off of ebay. like i previously stated, ingalls website lists 12mm as fitting my car. 12mm is too small! i'm going to try the 14mm... for the altima, part number 81260.
Re: Alignment question
Originally posted by Akhu I replaced the shocks and coils on my car(1996 s14) car over a month ago. i noticed when i replaced them, all the boots were deteriorated and the insulators were worn through on one end. i bought new boots and plan on installing them when i get some more parts so i can give it a one shot fixes everything day. where can i get the coil spring insulators(the sleeve type isolator things that go on top and bottom of the spring when connecting it to the strut/mounting plate? i searched kragen, autozone and pepboys and came up empty... how much can i expect to pay? http://www.ingallseng.com/parts/81250.htm i need to get adjustable camber bolts for my lowered car, sitting on sportlines and the front camber is totally negative. has anybody bought these for their car? if so, do they fit well? pdm racing quotes that the 95-98 needs 14mm bolts but ingalls lists 12mm... |
