project hydrplick e-brake
Old 12-28-2009, 04:25 PM
jcl666's Avatar
this is a k-sport hydro ebrake kit , tell me what you think about it.
jcl666 is offline
Old 12-28-2009, 04:29 PM
jcl666's Avatar
by the way sorry about the penzoil disel oil bu i use it to paint the under of my car with it for rust protection cause i loive in a crapy place called quebec canada ,
jcl666 is offline
Old 12-29-2009, 10:59 AM
you might want to resize the pics.
jramosthe1st! is offline
Old 12-29-2009, 02:59 PM
cool.. but.... stock Ebrake with new pads is good enough. Dont take your stock ebrake out of the equation. Its been noted that the BMC life is killed when using a Hydro setup.
Biggamehit is offline
Old 12-29-2009, 07:44 PM
jcl666's Avatar
seriously the brake master cylinder takes a beeting?? its weird , how come? i have a valve in the k-sport hydro ebrake that closes the front lines , so i cant brake the front wheels by pullin the hand brake
jcl666 is offline
Old 12-30-2009, 12:47 AM
don't quote me on it.... I should not have said that... Its based off of what a good source said.. however I don't like to go by hear-say.
Please resize pictures bro
ps
you have Z32 calipers. do you have a z32 BMC??
how do you keep you car from rolling away??
Old 12-30-2009, 07:09 AM
jcl666's Avatar
i kept my stock automatik brake master cylinder , and it is very very stiff , some peaple say that if you keep stock master cylinder it will be very very soft and spungy , but i have stainless braided lines on all 4 corners , and i by passed my abs , so maybee its because if that i like the feel , the only down side it that when i press on the brake i canot use the hand brake , neither can i press the brake when im pulling the hand brake. thats the only down side i found. but the amount of brake power you have at the disposale of your right hand is just amazing! im going 140 150 , pull gentely the hand brake and there it goes, rear wheels a locked. i had project u pads with good caliper before , and it just wasent enought.
jcl666 is offline
TSR20
11-12-2004 11:36 PM
jdmsoarer
04-17-2004 10:59 AM
jdmsoarer
04-06-2004 05:56 PM
SlydeSHO
01-22-2004 04:20 AM
dkdeleon
11-14-2002 11:33 AM
Quick Reply: project hydrplick e-brake
