Brake Fluid story
...so I go to the mountains a lot, and drive my car hard. Anyways, last weekend I noticed my brake pedal was getting closer to the floor. I figured my brake pads were on their way out because of all the mountain driving. Then yesterday afternoon when I started up my car, I stepped on the brake as usual and it made this really loud noise. Everytime I slowed down it would make the same "friction" noise. So this morning I popped the hood on a hunch and checked the brake fluid, and it was super low! Refilled the sucker and everything is fine.
Turns out the outside of the brake fluid filler has a darker bottom half so it looked like it was fine (on the outside). So yeah... check that brake fluid :D |
woah, the break system is a closed system..
where the hell did it go? evaperate? |
You must be killing your brakes dude lol :p
leak in the system? |
Thought about that but there's no tell-tale drips... I'm gonna clean out the area near the master cyl. etc. and see if I can't find any clues
if its a leak then youre brake fluid is going to easily rust through anything it touches
My brake master got a leak and ate the paint off of the booster and the frame rail before I changed it out :angry:
oh yea?? my brake fluid leaked on my BELOVED TE37's~! well only the drivers side is messed...i managed to wipe off the other rmis in time.....like the paint is all rough now....and i have white rims....DAH....F that brake fluid
my brake fluid used to leak out from where the plastic bucket mounts to the metal.
