Camber kit question(S14)
I just installed my cusco comp-s coilovers and went to get the car aligned. I am told I will have to get a rear camber kit to ajust the car. Did they meant only rucas(rear upper camber) or more than that ? Cause the guy was charging 425$US of parts for both side. I said no and will buy the parts. What would I need (parts) and where whould I get it (online)?
Thanks, |
yes, rear upper control arms will adjust the camber. phase 2 motortrend, jspec, etc. there are many other reputable online shops, theres a stickie of a list somewhere
does anybody know the range on the factory adjustible camber bolts? |
Camber is unadjustable from the factory....need adjustable RUCAs for rear and for front a cheap option is to get pillowball upper mounts....the ones from TEIN have bulit in camber plate, so you can adjust like +/- 5 or 6 degrees (way more than sufficient)
Originally posted by jspaeth Camber is unadjustable from the factory....need adjustable RUCAs for rear and for front a cheap option is to get pillowball upper mounts....the ones from TEIN have bulit in camber plate, so you can adjust like +/- 5 or 6 degrees (way more than sufficient) |
Originally posted by jspaeth Camber is unadjustable from the factory http://img119.imageshack.us/img119/5155/camberyk4.jpg |
Yes I am a dumbass ....stupid mistake, rear camber IS adjustable....sorry
I should know this since I took my stock RUCAs off like 2 months ago. SORRY! |
