clearance
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA%3AIT&rd=1
Anyone knows if this would clear z32 brakes? |
hmm looks like your gonna need a spacer.
nope...it's not gonna go in. The wheels you're buying a 4 lugs and z32 are five lug. i think it's going to be pretty hard don't you think. or i might be wrong, but i'm 90% sure.
you don't need 5 lug to put on z32 brakes. You will need the clearance and re-drilled rotors though. (if you plan on keeping the 4 lug setup that is...)
Originally posted by ninedy_to_koop nope...it's not gonna go in. The wheels you're buying a 4 lugs and z32 are five lug. i think it's going to be pretty hard don't you think. or i might be wrong, but i'm 90% sure. Cowboy Turbo is right. When I test fitted the same wheel just slighty different specs i needed a 5mm spacer to clear Z brakes. Good luck. |
Originally posted by ninedy_to_koop nope...it's not gonna go in. The wheels you're buying a 4 lugs and z32 are five lug. i think it's going to be pretty hard don't you think. or i might be wrong, but i'm 90% sure. |
