E-Brake
how do u adjust the e-brake. I adjusted inside teh car under the center console. do i have to adjust it under the car also
should be just under the center console
Take off the E-Brake vinyl cover.
There is a 10mm nut on a bolt that connects to the E-brake cable. That nut can tighten or lossen the nut for the E-Brake. You will need a 10MM DEEP SOCKET. So with that adjust and try it out till you feel what is best for you. |
