jennerda |
10-06-2002 09:07 PM |
help with struts for 1995 240SX
can someone offer advice on a problem i have removing a front strut bolt? i'm unable to remove the lower bolt that attaches the strut to the steering knuckle. i have this problem with the same bolt on both struts. the upper nuts and bolts came off freely, and the lower nuts also came off freely. however, the lower bolt will not move. i've tried heat, penetrating oil and attempted to hammer the bolt back through the hole. nothing, it won't move. i wonder if this is a manufacture's trick to prevent the do-it-yourselfer. has anyone had this problem? would greatly appreciate any tips. otherwise i get to pay the $525.
