hub question???
Can someone tell me if s13 hubs will fit on a s14, the reason i am asking this is because someone i know has some new curcuit sports hubs for sale. but all the sites i look on says nothing about them fitting on the front of the s14. i have been searching fort This answer and can't find it any where. i do have a base model s14...
Hmm it might fight, the rear definately would but Im not positive about the fronts. If he had to convert to a S14 Knunkle then, obviously, yes it would be perfect.
s14 stuff will fit on s13, but only some s13 things will fit on s14, if you wanted to put the s13 front spindle on a s14 i don't think it's ganna to fit. only b/c you need the s13 spindle to put the front hubs on
what about just removing the s13 bearings and changing out with s14 bearings. that should work i would think,or is there something else differant about the s13 and 14 hubs besides the inside diamiter of the bearings..any more idea's. thanks everyone.
no nothing else is different just the 5 lug spindle is bigger
ok.. so the s14 4 lug spindle is the same as the 5 lug spindle? i guess i'll just have to buy 2 se front hubs, and change out the studs for the extended ones from the curcuit sports hubs since the rear already works...
yeah ,they should be the same size
