Jdm R33 Big Brakes
link don't work
I can't get it to work
but ti's $500 with a rear 4-5 lug kit http://i3.ebayimg.com/03/i/04/ce/ea/b3_1_b.JPG |
Well I hope that it's a good kit because I just bought it! I've been monitoring these since they were $500.00 buy it now but as soon as it got down to $400.00 I didn't hesitate to click. It's really a good deal, at least I think.
looks like you'll have to get the rotors resurfaced, other than that, it seems like a good deal
you will need the ebrake system which is does not have.
if you want ebrake. those are GTS-T brakes too. GTR had brembo's. |
Is there any way to convert my ebrake setup for this kit? Or do I need the original ebrake cables for the R33? I bought this ebrake extension kit on ebay which I thought would work. If it doesn't I'll probably give it to my lil bro who just got his 89 240sx.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=8005364375&sspa gename=STRK%3AMEWN%3AIT |
^ no you have to buy the ebrakes that are supposed to come with it. no other way around it.
I think I just misunderstood you. I did get the ebrake drum system with the backing plates as well when I picked up my brakes from the seller. I just need the cable. That kit on ebay should work right?
Originally posted by LandHo_S13 you will need the ebrake system which is does not have. if you want ebrake. those are GTS-T brakes too. GTR had brembo's. the pictures suck but they could be those larger rotors/calipers from the R33. but you might want to compare them to the Z32 rotors. and if they are larger, i don't think they fit under 16" rims or smaller. |
those look like 13" rotors. if so then they are plenty big. you may lock up the brakes easier in wet conditions.
