-   Suspension, Chassis, and Brakes (https://www.s-chassis.com/forums/suspension-chassis-brakes-15/)
-   -   knockin sound (https://www.s-chassis.com/forums/suspension-chassis-brakes-15/knockin-sound-12227/)
bo2o May 4, 2004 12:11 AM
knockin sound
thers a knockin sound wen i reverse n stop is that normal?
would it be my sway bars? and wat if i upgrade them would it be better? or add a rear strut bar?
i wana drop my car i hab stock sprngs n shocks
wat would b the cheapest way to do sum other than cut them
Blacklabled12 May 4, 2004 12:30 AM
knocking = BAD ..... check out the boots on your back axle.. if the're broken ... bad news .. it also could be your tierod or Tierod ends ends on your front wheels, agian check the boot and if it's broken . with suspention stuff like that.. when it starts making big noises it's already to late and they will need to be replaced..... if it is your suspention... it could be any # of things ... Is it one big knock or is it series of little knocks ... and does your car vibrate or jolt when it clicks ?
twofortyessex May 4, 2004 08:54 AM
hmmmm, mine does this too. but only when I'm parked on a hill and have used the hand brake to hold the car. when I start moving backward it goes thump and shakes the car a little bit. if I'm parked level it never happens.
bo2o May 4, 2004 04:25 PM
well lets say im reversing and thien all the sudden go back to first to go forward well still rolling thers a sound or juss stopin it happens only on reverse though. is it that bad? its only one knock
