Parts Needed for Brake upgrade?
im looking to do the z32 brake upgrade on my 240, first of all is there any difference between the z32 and r32 brakes? and are z32 off of the twin turbos only or on the NA too? last and most important question, what parts are needed to do the conversion for the front and the rear, i want to switch the whole car to 5 lug. thanks
i'm not very experienced with 240's but to switch the lug pattern i think you'll need to change the wheel bearing. could be more work then it's worth.
Hi,
I am planning to do the 5 lug conversion as well, but am looking to see whether the benefits are outweigh the costs to do it. here are couple links that talk about the conversion. If you ahve questions, post them and I will try to answer them, since I am n00b and haven't actually had experience doing the swap, jsut reading a lot online Links: http://importnut.net/300zxbrakeswap.htm http://www.nissanperformancemag.com/january03/240sx/ http://www.sportcompactcarweb.com/te...cc_projsilvia/ Hope this helps. Cheers, Gus |
