Question about 350z brakes and a few others . .
Non brembo 350z brake calipers:
I have read that the only thing that you need to do is drill a bigger whole and get shorter bolts.
Would you guys recommend this upgrade?
Would I also need a 300zx BMC? - probably for a better pedal feel.
On a side note:
Would a 1000 lbs engine crane (cherry picker) be good enough to pull a SR20 or KA24 or a VG30 (from 300zx 6 cyl) ? ?
Thanks guys,
RickY
On a side note:
Thanks guys,
RickY
1 ton is 2000lbs if your motor weights more then 2000lbs then you shouldnt own that car...
lol
anyway yea depending on the v-6 should not be over 700-800lbs with tranny thats not even half of the hoists capacity
just make sure the chains can hold the weight. with my SR i used a seatbelt it worked fine i think SR with tranny is like 500lbs or so
lol
yashios14
Dec 7, 2010 07:47 AM
ErizSR
Jan 19, 2010 07:26 PM
