Rear Caliper Removal
Old Sep 3, 2007 | 04:24 PM
positron's Avatar
When removing the rear calipers/lines and you have to drain the brake fluid, where should you drain it from. The caliper bleeding screw, the brake line banjo fitting on the caliper or the brake line where it connects to the chassis?
Old Sep 3, 2007 | 04:46 PM
it doesn't matte where you drain from, the important part is that you bleed the lines after everything is put back together. long time no see where you been?
Old Sep 4, 2007 | 02:08 PM
positron's Avatar
I had a busted modem for almost two weeks but now I'm back!
Linkagge
Sep 9, 2004 10:51 AM
PissonH
Aug 28, 2004 11:45 PM
DRFT240
Apr 24, 2004 12:17 AM
MurdarioStomp
Mar 21, 2004 03:39 PM
Import Fanatix
Oct 4, 2002 12:54 AM
