Rear end moves around from bumps...
not sure if i'm parinoid or what but I have started to notice that when I hit some bumps the rear end seems to yaw or shift to the right. more so at low speeds, also a few times I have pulled her hard arount... say a right corner and if my rear right tire hits a bump its seems to shake or vibrate for a second. hard to explain. either way its disconsurning. cant see anything unusall under the car (i'm not all that expiereiced anyway). thanks for any ideas on what this could be.
ok maybe i'm crazy just went for a rip through buisness park close to my house and it dident move or vibrate the rear end at all. lol I dont get it. saving up for megan coilovers anyway.
sounds like you need some subframe bushings...or spacers=) your bushings could be worn so there is gap or play for it to move around
mine did the same thing, after coilovers and subframe spacers its like 99% gone, hardly ever happens nemore
right on thanks guys, guess I'l just have to wait for my coilovers and maybe get some new strut bars and sway bars aswell if I have the $$$
I'd get coilovers before strut bars, they probably make the least noticable difference by themselves. I'd get sway and coils first if I were you.
subframe spacers are less than 100 dollars and that would probally fix the problem your having...atleast most of it.
ya get an alingment
