rear hub removal on an s14
ok so I'm in the middle of my 5 lug conversion on my zenki, and I'm just wondering how you remove the rear hub. I removed the caliper, the bracket for the caliper, the rotor, and the cotter pin, but I'm kind of lost after that, there is some kind of funky nut on the axle that isn't like the 32mm on the front, do I need to just remove the funky nut somehow, or do I need to remove something else.:dunno:
appreciate the help thanks |
Here this website will help you to complete your conversion.
http://importnut.net/300zxbrakeswap.htm Good luck... |
You need to remove the funky nut off the axle and the 4 bolts on the back of the knuckle.
