RS*R D1 SPec Polyurethane bushing Kit for Nissan S13 240SX 89-94
Old Aug 16, 2005 | 01:13 PM
keirnna's Avatar
Has anyone else ordered or installed these? http://rs-r.com/news/?art=44
I ordered them last night for around $200 shipped. I hope to have them in by the end of the week, and if my swap is done I'll start installing them. I just wanted to know what results others have had. From RS*R:
Originally posted by RS*R This D1 Spec kit replaces key components such as the front strut rod bushings, front and rear control arm bushings, and front and rear sway bar bushings, but RS-R felt that there should be more to this kit then to just improve these suspension components and took this kit to the next step. To supply the performance enthusiast with their high needs of drifting and road racing, RS-R felt the next step to improve the cars performance is to include polyurethane bushings that replaced the rack and pinion bushings, and rear subframe mount inserts. The rack and pinion bushings improve the response of the steering response from the steering wheel to the front tires. While the rear subframe inserts improves the response of the entire rear suspension by minimizing the play from the rear subframe.
Old Aug 16, 2005 | 06:31 PM
Monkey Boy's Avatar
i hope you have a press to do this because if you have to have a shop do it and you don't have the hookups it may get pricey. pdm racing offer new control arms with bushings already inside. anywho post how it goes and your thoughts.
Old Aug 16, 2005 | 06:37 PM
keirnna's Avatar
Yeah I have access to a press.
Old Sep 29, 2005 | 09:17 PM
silver240esex's Avatar
Just wondering if you already have them on. I'm considering buying the same set but I still need to do more research on them. If you have them on already, how do they feel?
Old Sep 30, 2005 | 03:33 PM
How are they? I'm thinkig of going with these instead of other brands
slappy
Jan 7, 2010 08:38 PM
aztectt
Jun 19, 2006 01:22 PM
HumanoidTyphoon
Jun 19, 2005 10:20 PM
TheStartingLine
May 21, 2004 12:01 AM
ebanfan
Oct 10, 2003 04:36 PM
