Sponsored by:
Sponsored by:
S13 Rear Upper Control Arm Install
Old 03-20-2007, 05:30 PM
positron's Avatar
I finally got a set of rear upper control arms in. Here's the install!
Tools needed:
Jack
Jackstands
Crescent wrench
Socket wrench
Socket extension
3/4 socket
11/16 socket
3/4 wrench
Breaker bar
Torque wrench
Small hammer
ProjectNissan RUCA's
The RUCA's should have been the first rear mult-link suspension part I upgraded but I didn't...Whoops! Jack the car up and put the jackstands in the appropriate places.
Next you'll need to get the breaker bar to bust loose the inner control arm nut.
After you bust it loose, get an extension on your wrench and the 3/4 socket to remove the inner RUCA nut.
Now get the breaker bar and the 11/16 socket for the outer RUCA bolt. You'll need to use the 3/4 wrench to hold steady the outer RUCA nut while you bust it with the breaker bar.
Next, you'll need to remove the lower strut nut.
Small hammer
Using the small hammer, gently tap out the inner RUCA eccentric bolt but before you do that you should stop and use a sharpie to mark the position that the eccentric washer was in before removal so you can put it back in the same position later.
Eccentric bolt and washer.
Now that you have the RUCA off you can slide it down the shaft of the strut assembly.
Push the strut to the side and remove the RUCA.
Take your new RUCA's and align them to the same length as the stock RUCA's.
Use a crescent wrench to move the washers.
Now you can put the new RUCA's into place, put your inner, outer RUCA and lower strut nut back into place.
Use the crescent wrench to tighten the RUCA washers.
Torque the inner RUCA bolts to 51-65 ft. lbs and the outer RUCA bolts to 57-72 ft. lbs. Replace the lower strut nut and torque to 57-72 ft. lbs.
Finished! Hit up the alignment shop.
positron is offline
Old 03-20-2007, 05:32 PM
nice write-up bro, its good to see some fresh installs with good pix.
RuizXIII is offline
Old 03-20-2007, 05:35 PM
^^^ x2 nice pics
sr91240 is offline
Old 03-20-2007, 05:38 PM
also how good of quality are the megan and project nissan parts i was thinking about putting the same on my s13
sr91240 is offline
Old 03-20-2007, 05:41 PM
positron's Avatar
I've only had the toe rods and traction links on for about 2 months but I haven't had any problems yet. I haven't driven on the ProjectNissan RUCA's yet but I'll let everybody know how they perform as soon as I do.
positron is offline
Old 03-20-2007, 06:00 PM
Copied to the FAQ section.
Bryan is offline
Old 03-20-2007, 08:53 PM
nice write-up, i installed mine a couple months ago...cant really tell a difference other than the adjustability..but the quality seemed good for the price
motegineon is offline
Old 03-20-2007, 09:15 PM
positron, you always have great write-ups. i think i shall gather all your stuff and merge/sticky them.
Ayuaddict is offline
Old 03-20-2007, 09:46 PM
positron's Avatar
Cool. Thanks fellas!
positron is offline
Old 03-20-2007, 09:49 PM
hows it working out for u
Biggamehit is offline
Old 03-21-2007, 07:13 AM
positron's Avatar
Took a drive last night but like motegineon said, I can't really tell much of a difference. Maybe a little more stable.
positron is offline
Old 03-21-2007, 08:37 AM
i c..
did you install metal collars yet... ill be addressing all that jazz soon enough.
Old 03-21-2007, 08:43 AM
it appears he did, you can see them in the pics...if ur talkin about the ones for the subframe?
Old 03-21-2007, 09:19 AM
damn your right. ( slaps self in the face)
positron
04-12-2007 03:52 PM
nismoman
12-10-2006 05:29 PM
Carparthookup
12-13-2005 09:47 AM
Evo3
01-22-2005 08:39 PM
jackyliem
12-25-2004 05:03 PM
Quick Reply: S13 Rear Upper Control Arm Install
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
