s14 front shocks vs s13 front shocks
by what i have seen in pictures the s14 fronts look like they are shorter then s13's is this true ? does any one have a side by side compairison of OEM or KYB's'? if they are shorter that means idealy its a better shock to use for lowerd s13's. just an idea since the coilovers are interchangable for the fronts...
There shouldn't be any height difference in the two. The main difference is the size bolts that go through the lower section. IIRC, the S13 accepts a 12mm bolt and the S14 accepts a14 mm bolt.
there isnt a size difference?... dam it... lol there goes my idea for short strokes...
aren't s14/s13 shocks up front basically the same everything (except for the lower bolt hole)? That's what I was told
Originally posted by JeromeS13 There shouldn't be any height difference in the two. The main difference is the size bolts that go through the lower section. IIRC, the S13 accepts a 12mm bolt and the S14 accepts a14 mm bolt. Isn't that what I said?? |
Originally posted by JeromeS13 Isn't that what I said?? |
| All times are GMT -7. The time now is 05:13 AM. |
