silkroad coilover question
alright i just got my silkroad coilovers for my s14, and im wondering what stiffness setting they come on from the factory? and does anyone have a link to the instructons in english? thanks cant wait to get them on so i can ditch my crappy tein flex lol
Settings are different on every coilover, well atleast a couple of mine were. Just turn them all the way to the left (now they are at full soft) and turn right to stiffen them until you're satisfied.
Now for instructions in english, good luck. Its very basic though, 5 bolts on each of the fronts, 3 bolts on each of the rears. Unbolt and them bolt 'em back up. If you wondering about english instructions you probably need to know preload & ride height adjustment. Unless you know suspension geometry and dynamics, you should just keep it SIMPLE. Put the preload collars against the spring and load it a turn or so. If you want to lower it use the lower perch adjustment, its the easiest. count thread or use venier calipers to make sure the fronts are the same and the rears are the same. |
