Some Help Please
Will these wheels fit my 95 240? Heres the specs:
Size: 17" x 7" Bolt Pattern: 4 on 100, and 4 on 4.5(114.3) Offset: +42mm |
no never not in a million years.
those are some weak ass specs. |
What are some good specs then so i dont get yelled at for the same thing twice.
im guessing your base model.
so you want width 8 or bigger and offset 20 or lower. |
Don't know who makes those rims but if your on a budget you can get some falken Hanabi wheels. 17x9 +20 offset. Not Überoffset but beter then putting a :barf: 17x7 +42 on a s14.
^ those specs arent bad.
Hey thanks guys. What are some good sites that i can find 4 lug wheels for around 100 a peice thatll fit my car. Ive already tried searching google n ebay but i cant get any good offsets or sizes. Thanks for the help in advance.
100 a peice? No place, look if you really need to spend little money on zilvia.net they have a groupbuy going for some rota rims. Rota makes realtivly lightwieght cast rims. The group buy is for 16x8 +20 or +10 offset for $650 you aren't going to find beter wheels for cheaper.
Wheels are not the place to cheap out on, if you really only have $400 to spend on rims search ebay for some enkei mesh rims 17x7 +0 offset they can normly be had for under that. Or look for other old used rims. Also offsets and read the info there if you find wheels and still have questions that arent there landho, myself are others can help you. |
Thanks i appretiate the help guys, it looks like im going 5 lug conversion and slappin some z32 wheels on there with TT front calipers. Itll be a nice setup and ill just save up for a set of nice wheels with some nice sticky tires.
Good idea, nice to see new members learn quickly :)
yes finally
