steering arm boots
steering arm boots
well i just did an oil change on my car and one of the steering arm boots was broken. does this mean i have to change my rack and pinion also? i am hoping that all i have to do is buy replacment boots and put that on when i do my tie rod ends.
just change boots, you should be fine
UNLESS there's fluid leaking from the upper rack part where the steering column attaches... or there's metal stuff flying out from where the tie rods go... or other obvious reasons to change the rack.
i am gonna change the tie rod ends. why should i change the rod itself? will it make my steering more stiffer and precise? i thought it would just make it stronger yet have no effect on steering precision. i am changed the tie rod ends as they are blown. just need a reason to replace the rods themselves which i don't see any. are there bushings on there that get worn?
but even if you're not upgrading, think about how old your car is. Since you're gonna replace the tie rod ends and boots, might as well get a fresh set of tie rods in there. It's not that expensive. Otherwise it's like getting your whole car repainted a fresh new shade of silver... except for the doors.
Aftermarket tie rods are normally stronger than the OE tie rods, and sometimes have a slight more adjustability for toe allignment over stock. If you're having to replace the boots now, might as well go for the full replacement if its within your budget.
It's personal preference, but I would suggest Tein's rods from www.enjukuracing.com . They seem to have a good price for these, and the kit from Tein (not sure about other brands) also include new tie rod end links for your car as well.
Any time you can replace an OE part with something stronger, I say go for it and save yourself a later hassle like a bent tie rod or stripped end link.
i got moog outer tie rod ends already, they are beefy like the tein's. http://www.pdm-racing.com/products/i...ges2814rl1.jpg
http://store1.yimg.com/I/jspec_1853_7269561
i figured if pdm were offering moog tie rods ends outer and inner it's worth a go. and i can get the moog stuff at list price.
Originally posted by namster180
btw if you mark your tie rod you won't have to do an alignment, if that is the only reason you're doing an alignment
RedlineGoods.com
94
03-16-2007 10:11 AM
Carparthookup
12-13-2005 09:47 AM
l2aine
13
12-22-2004 12:34 AM
RedlineGoods.com
09-15-2003 11:59 PM
jujeracing
02-12-2003 09:55 AM
