tie rod/tenson rod
tie rod/tenson rod
o man..... im stuck can anyone help me? ok first part im stuck on is that my bolt that holding on the tenson rod is stuck and i cant move it AT ALL its slowly starting to chip away at my effort to take it off.... iono how to take it off anyone got any ideas....my second problem is im trying to put on tein tie rods w/ ends.... im stuck on removing my stock tie rod... i got the ends off the knuckles but i dont know how to remove the actuall rod... i dont know if im spouse to take off the locking plate or not... i dont even know how...can anyone help me.... can anyone give steps... i lookd in the repair book thingy... it only tells me how to take off the ends....
-thanks
-thanks
Re: tie rod/tenson rod
-thanks
-thanks
lol i was doing both things.... lol i have bolts that wont come off...when i was changing my tenson rods.... and for tie rods i figured out how to take it off... i just need to get new boots now... i just need info to take off bolts that are stuck like a ****...
thanks for the offer tho...
BTW do you go to TAB Tuesdays?
lol i tried i couldnt get thoes bolts off =( iono ima try air tools tomorow...
i use to go to play pool at action before i had a 240... i hvnt been there w/ my 240
Air tools? damn... something is wrong LOL
the large bolt holding the front of the tension rod to the front brace lol hmM... iono i just put a socket on and turn it lol? how else r u spouse to take it off ? =(
ya i was using one around that size with a pipe at the end i was using a 17mm socket that shiet wont move =( did your brake caliper get in the way? i kinda stripped it a bit =\ cuz i wasnt like exactly straight =\ stoopid of me.... i wanna start working on the side where the nut is... but i cant get a breaker bar under my car....
