Which tires for drag?
Alright I got a quick question for those drag racers. I happen to have a set of Falken Azenis RT-215 205/50/16's and a set of Falken ST-115 225/45/17's. Which set should I mount on the front and which should I mount on the back for RWD? Should I go with the wider 225's? Or the more drag slick designed and less rotational mass 205's?
umm those arnt drag tires if you are going to be drag racing buy some slicks or some real drag radials. and if you cant figure out what to put where you need to sell the car
"the more drag slick designed" Read correctly before you make stupid comments, I simply stated that they were better designed for drag than the St-150's because of their wider tread pattern.
how bout you read what i said because its obvious you didnt
c'mon now guys
one of my many motto's:
"Don't half-a$$ anything" that being said, get some Mickeys on 14-15" wheels. Circular makes nice drag wheels. edit: I meant to say Circle wheels. get 'em mixed up... |
