urgent question
can anyone tell me if the tie rods, control arms, sway bars, and crossmembers of a 1989 240 are the same as a 1992? i recently busted all these parts hitting a curb and the only model at the salvage yard is a 92. any help is much appriciated.
thanks, alex |
sway bars are the same but the tie rods and control arms are different but i dk about the crossmember
i think there all the same thing.
thanks for the replys, i just found something about a limited edition se fastback with stiffer suspension for 92, maybe its the 4 wheel steering?
the SE ones had thicker sway bars.
i checked on a replacement parts site it said they were different but i dk
89-93 suspension parts are all the same unless its a hicas model. Since 94 was convertible i think the rear shock was a tad different.
If you are not sure please dont spit useless information. |
Originally posted by Levi SPL S14 89-93 suspension parts are all the same unless its a hicas model. Since 94 was convertible i think the rear shock was a tad different. If you are not sure please dont spit useless information. |
hicas has thicker rear
ahh ok
yeah it was hicas stupid car got all the good **** well except the hicas part.
thanks everyone, giong to the salvage yard today. ill post again with the results
All S13 models (89-94) except hicas have interchangable parts.
All S14 models (95 - 98) are built the same. Only difference I see in S14 chassis are weight. SE being the heaviest and the LE being the lightest. But I rather get SE anyways to save time from doing 5 lug conversion and to have a stiffer chassis. Everything on that car in the salvage yard should swap in to your car like cake. |
control arm, radius arm, and sway bar all fit great. had to buy a tie rod though. no matter how many times i do suspension work i can never remember this so i thought i would share;
ALWAYS put the nut back on the control arm before pounding. i mashed the threads and had to get a tap and die set, but then returned it, thanks harbor frieght :). thanks for the feedback everyone. alex |
