when replacing suspesion....
What else should i look at/replace? My KYB AGX shocks/struts and Tein S-Tech spings should be here mid-next week, so i figure while im gettin dirty, might as well check out what else should be replaced.
thanks |
Rotors and Pads, bleed brakes(more then likely needed, a lot of people don't replace their fluid), clean up under there cause it gets dirty, Swaybars/endlinks...and then get a GOOD alignment
allso take a look at your TC control rods, see if the doughnut shaped bushing is cracked (it usually is) at which point get some tein pillowball tc control rods, don' go w/ polli bushings b/c you'll crack your control arms. there's about 5 other bushings in there. if you go to pdmracing.com it'll list & show installs on most of them. they're good but expensive. but their how-to's are free! :)
anyway. that's my .02 |
