Where to have my 300ZX rotors redrilled?
I live in Greenville, Sc and I was wondering where I could get my 300ZX rotors redrilled for 4 Lug. I know not many members on this board are from around my area, but what kind of shop do I need to look for? A machine shop, brake shop or what? If anyone knows of any shops in the Greenville, Charlotte, Or Atlanta areas, that would be great.
Thanks a ton. |
Check a phone book for local machine shops, they should have a drill press and be able to do it for you.
+1 for machine shop with drill press
Cool
Ok, well I didnt know it was that simple. My best friends dad owns a machine shop. What is the best way to make sure the lug holes are centered perfectly around the hub. Should i use 1 of the pre-existing lug holes and drill 3 new ones. Or should I drill 4 completely new ones. I guess I could use an old rotor for a template. thanks
You could just use the old one as a template, just lay the 240 rotor on top of the Z rotor and have them drill down through the 4 lug holes,
thanks again.
Another option is having a spare hub with 3 of the for studs out. Run one of the studs through oneof the existing 5 holes and drill through the other 3 holes in the hub. It'll line up perfectly
Oh Ok, thanks Artic. Thats what i really wanted to know. I was unsure if the if the 4X114.3 would line up/be centered using a pre-existing lug hole on the 5 lug. Thanks again, that is what I will end up doing.
