Wide rims
Been looking for some time now, and haven't come across anything that is within my budget.
Basically I'm trying to find a 17x10.5-12 rim that weighs less than 25lbs. I've seen those mustang rims on ebay and whatnot, but they weigh 36lbs! Everything else seems to be $800+ per rim. Do any of you guys know of some rims that are both light and relatively inexpensive? If I can't find anything I'll probably end up going with some FN01-Cs (17x10) and run a 285 or 295 tire until I can afford some custom rims from either Jline or CCW. |
The wider, the more expensive they are.
You could also try 18's..some of them really have wide width. IE 18x12... Also 285 in a 10 is superweak. SUPERweak. |
I've looked at 18s also...but it's just more money for both the rim and the tire. Also, 17's would serve my purpose better (drag).
I wouldn't exactly call 285s weak, especially if you're running comp tires. A friend of mine has the new C6 Corvette which has 285s on it, and they look pretty mean. |
you want 10.5j + wheels then you have to pay.
no other way around it. |
