Z32 brakes
I was wondering what the minimum wheel size is that you can run on these was? I would like to put on some 15 inch axis oldskool's on the car they dont make a bigger size.
Check the Sticky
I don't think you need Z32 brakes if your looking into getting Axis OG Wheels.
And Im pretty sure the smallest size that would work is 16-17". Stock Z32 wheels are 17" |
I believe the stock 7 spokes can work if you get the right ones without the ridges on the rear, so you might be able to clear with 15's, however, the one thing you will have to look at is spoke design to see if the caliper will clear the wheel.
Yeaup..
Courtsy of Nico ( look at hub) wheels that do fit http://is.rely.net/3-40-1353-l-eSzEB...esdqxYXf9g.jpg wheels that dont fit. http://is.rely.net/3-40-1354-l-RE8Eq...gp50tjGNgA.jpg |
it's just an Idea I just bought the car as a project or money pit It'll be one of the two. I would assume I would need spacers Im mainly looking to see that the caliper will fit in the wheel it self.
the smallest wheels u can put on ur car with z32 brakes are 15" my friend has stock se wheels with 30mm z32 brakes and his clears fine with no spacers
Originally Posted by cencal_toast
(Post 324564)
I was looking into the same thing
I was thinking about some z32 brakes. are the pictures shown of the stock steelies? or are they of stock se or z32 rims? i was told that the best size is a 17"x7 with a 25 offset. can any one else give me some preferred rim sizes for the z32 calipers?
Or off set at that?
The pics above are the stock 7 spoke alloys
Originally Posted by RuizXIII
(Post 324370)
http://nico.dreamhosters.com/hosting/fsm_z32_wheels.jpg |
(Post 324370)
on a 240sx z32 calipers are useless if you dont have the right size tire to back it up most of you guys like stretched tired here but with that they lock up real easy and are basicly useless. big brakes mean nothing if you dont have the grip to stop and thats a fact
(Post 331204)
